A WireFlow Battery Solution
WF Bifrost Series
The WF Bifrost Series is a flexible and powerful platform designed to meet the needs of the entire battery value chain.
WF Bifrost Module Tester
Figure 1 WF Bifrost Battery Tester
Built on WireFlow’s Valand Battery Test & Measurement Platform, Bifrost enables engineers and operators to safely test, charge, discharge, classify, and validate batteries throughout their lifecycle. From research and development to production testing, reuse, and recycling.
Each system is modular, configurable, and scriptable — combining hardware precision with software flexibility to deliver exceptional control, safety, and data traceability.
Figure 2 Battery life cycle
One Platform – Multiple Applications
We offer both pre-configured solutions and customised systems with different functionalities to deliver a solution meeting your specific needs.
Research & Development
For labs developing new battery chemistries, modules, and packs, Bifrost provides complete test control and automation. Engineers can script and execute custom test scenarios for performance, endurance, and safety validation — accelerating innovation and data insight. Read more about Research & Development.
Production & Quality Testing
On the factory floor, Bifrost systems deliver automated end-of-line testing and charging with high reliability. Each battery is identified, configured, tested, and charged to its target SOC — ensuring consistency, traceability, and readiness for shipment or integration. Read more about battery manufacturing.
Repair, Reuse & Refurbishment
In aftermarket and remanufacturing settings, Bifrost safely tests and classifies batteries for second-life use. The platform measures state-of-health, verifies communication, and ensures modules are fit for reuse before reassembly.
Recycling & Energy Recovery
For batteries at the end of their service life, Bifrost supports controlled discharging and classification. The system ensures safe energy recovery and prepares batteries for dismantling or recycling — fully aligned with circular economy principles and EU Battery Regulation requirements.
WF Bifrost Series is powered by the Valand Platform
At the heart of every Bifrost system lies Valand, WireFlow’s adaptive and scalable software platform for test automation. It’s plug-in framework makes it simple to integrate new instruments, I/O modules, or measurement devices as research evolves. Hardware is automatically detected and ready to use.
Scripting
Engineers can create their own tests using Valand’s scripting language.
The built-in editor validates syntax and includes comprehensive help documentation.
All system variables are exposed within the scripting environment, allowing both simple and complex tests — from SOC or voltage cycling with coulomb counting to advanced fault-injection sequences for validating BMS logic.
Safety
A background alarm system continuously monitors user-defined variables (for example voltage, current, temperature). If a limit is exceeded, Valand automatically places the DUT in a safe state.
Logging
All accessible data variables are logged during each test. Results are stored in uniquely named folders, easily exported or analyzed with external systems which ensures full traceability for both development and compliance reporting.
Centralized
The system is controlled by a user-friendly software as a single point of contact. All stations can be run simultaneously and independent from each other and are controlled and monitored from one application.
Integrable
Using our Rest API or Modbus-TCP, you can communicate and control the system from any adjacent system making it a seamless part of your production and test infrastructure.
Upgradable
All products in this series are based on the Valand Battery Test and Measurement platform making it possible for customers to upgrade the systems with new versions and customer specific functionalities if needed.
WF Bifrost front end user interface
Figure 3 – EV battery prepared for test
Downloads
WF Bifrost Series
AB0005-149 WF Bifrost Series.pdf
