A WireFlow Battery Solution
Solutions for repair, reuse & recycling
The WF Bifrost Series is a flexible and powerful platform designed to support the transition towards a more sustainable and circular battery industry.
Figure 1 – Â WF Bifrost Battery Tester
By streamlining the testing, discharging and classification of batteries ahead of refurbishment, reuse or recycling, Bifrost helps enable the goals and processes promoted by the EU’s Battery Regulation.
Bifrost handles multiple test stations in parallel and can process batteries at different stages of their lifecycle simultaneously. The platform identifies battery condition, qualifies it for reuse, or prepares it for safe discharge prior to recycling where energy is efficiently recovered during the process.
All monitoring and oversight are centralized througt our Single Point of Control concept, providing full control, high safety and operational efficiency.
A battery solution developed for real-world industry needs
The Bifrost platform has been developed in close collaboration with industry partners and is currently used in several critical phases of the battery lifecycle:
- Aftermarket & Refurbishment
- Remanufacturing & Repurposing
- Recycling
Compared to other available products in the market, our modular series provides you with all you need to shift seamlessly from simple to advanced test and measurements with the possibility of a high degree of customization.
Figure 2 – EV battery pack prepared for discharge
Features of Bifrost
- Fast and safe battery discharge to zero volts prior recycling with WireFlow TotalDischargeâ„¢, ensuring no energy left in the battery
- Flexible modular charge/discharge system for safe testing, reconditioning, and module replacement within battery packs, supporting efficient repair and second-life use
- Individual cell voltages measurement for safe charge/discharge operation and more precise SOH qualification
- State of Health measurement with standard or customized test protocols
- Temperature monitoring and reverse polarity protection for reliable operation
- Reusing recovered energy internally or feeding it back to the grid
- Maintenance and transport charging capabilities
- Full process documentation ensuring traceability for audits and customer compliance
- Automatic work reports providing insights into utilization and efficiency
- Seamless integration with production and IT systems for a connected workflow
Figure 3Â – WF Bifrost front end user interface
* Voltage and current can be from 0 to maximum specified
** Advanced SOH: We also offer Advanced SOH measurements by using data analytics providing an extremely fast test process that is tailor made for your needs. Please request more information if interested.
More about the Bifrost platform
The WireFlow Bifrost Series is a modular, programmable platform for battery testing and energy management across the entire lifecycle — from research and production to reuse and recycling. Built on the Valand software platform, Bifrost combines precision hardware with powerful scripting and data logging capabilities.
Downloads
X_WF Bifrost Module Tester Series
AB0005-134, rev B Bifrost Module Tester Series.pdf
Complementary products for Reuse and Recycle
Contact info@wireflow.com for more information.
Container for safe storage of batteries when discharged
Hydraulic lifting table
