Downloads, Information & Videos
Downloads
LabVIEW Driver
User Manual
Data sheet
Additional Downloads
Mixing WF and NI modules
WF modules and Scan mode
FPGA Resource Usage for WF C Series modules
Integrating WF modules with NI VeriStand
Specification
– Max Voltage; 58 V
– Max current; 2.5A/ch (6A peak < 100ms)
– Ch. resistance; < 0.1 Ohm
– Max power dissipation; 1.5W/module
Features
– Entirely solid-state design
– Two general purpose short circuit rails.
– LabVIEW driver included
– Compatible with NI VeriStand
Application areas
– HiL testing (Hardware in the Loop)
– FMEA tests
– Fault simulation
Shipping information
– Product Net Weight: 0.17 kg
– Country of Origin: Sweden (SE)
– Harmonized System (HS) Code: 85371091
Support & FAQ
Visit our knowledge base on our Support Portal if you don’t find any answers to your questions here.
General information
Can I use ScanEngine for the module?
ScanEngine access is not directly accessible for Third-Party modules, but it is quite easy to mix WireFlow C Series modules with other NI modules in a system and still access the NI modules in Scan Mode. Please see application note AB0005-056 AN4 Mixing WF and NI modules for a step-by-step guide how to do this.
What kind of connector are used for the module?
The WF 3154 and uses a 10-Pos Plug. You should connect a terminal block for 10-Pos Plug to the module. This terminal block is included together with the module when shipped from WireFlow.
Is the WF 3154 module compatible with cDAQ-systems from National Instrument?
No it is not. At the moment only the WF 3132 module works on both CompactDAQ and CompactRIO systems. The WF 3154 is for time being only compatible with the CompactRIO systems, including the expansions chassis for Ethernet, EtherCAT, R Series and MXI-Express. However, National Instruments has released a CompactRIO series that supports NI-DAQmx, called NI-904x (you can find them HERE). On these chassis you can use all of our C Series modules.
How many FPGA resources does a C series module consume?
The FPGA usage of a specific software and hardware combination is affected by multiple factors such as; FPGA type and size, compilation options, the random starting point for FPGA code placement etc.
Hence, it is impossible to derive an exact figure that defines the FPGA usage of a specific C series module. For customers that are uncertain on whether their application will fit on a specific FPGA with a WireFlow C series module it is recommended to make a test-build. Note that no hardware is needed to make a test build. For more details, please see AB0005-104 AN16 FPGA Resource Usage for WF C Series modules.
ECU test demo
NI Alliance Partner, WireFlow AB, shows a demo that illustrates how a simple Electronic Control.
